In September 2021, it can be successfully installed diversion on 380.65. Now it shows that it cannot be installed,
and the error "curl: (60) SSL certificate problem: certificate has expired
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using
a "bundle"
of Certificate Authority (CA) public keys (CA certs). If th
e default
bundle file isn't adequate, you can specify an alternate fi
le
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA repre
sented in
the bundle, the certificate verification probably failed du
e to a
problem with the certificate (it might be expired, or the n
ame might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certifi
cate, use
the -k (or --insecure) option."
You can't use "-- K". Is there any way to continue installing drivesion? Thank you very much!
a "bundle"
e default
le
sented in
e to a
ame might
cate, use
