Calisro
Merlin, would you consider allowing us to override the default certificate for https with our own by placing override config files in jffs/config? I've done what is in this link and it works but my problem is:
1) it takes a large amount of nvram to hold a quality cert and ca.
2) It would be nice if I have to factory reset, that it would pick up my new cert easily with my replaced jffs configs rather than messing with doing it manually.
reference:
https://gist.github.com/davidbalbert/6815258
I'm sure I can just hack my own startup script to fix it after a factory reset but the nvram issue remains.
reference:
