Change in UI Failure with Merlin 378.56
cpu
After installing 378.56 on my RT-AC3200 I noticed after 3 days 12.5 hours that I could no longer login to it via HTTP. No problems getting into it via SSH and it appeared to be routing traffic with no problems. Is there some way to restart httpd ?
Of course rebooting it resolved the issue. I recently reset the device to factory defaults and upgraded it to 378.56. In this past when I could no longer login via HTTP, I could not login via ssh either and was forced to power cycle the unit, so this is an improvement.
This unit is configured as an internet gateway to a 30mb up/down via a microware. It doesn't seem to matter which of my ASUS routers I put in this location, an RT-AC66, An RT-AC68 or this RT-AC3200. All of them seem to have the same issues after 3-10 days. Setup as AP's they seem to run forever. Using ASUS firmware get's similar results. Of course the RT-AC3200 is so much faster then the rest, especially for access to the storage plugged into the USB3 port.
Router runs out of memory after a while due to intense debug logging left in by Asus. The debug log has been removed for the next release.
Problem back after
admin@RT-AC3200-36A0:/tmp/home/root# uptime
09:05:25 up 7 days, 15:46, load average: 0.00, 0.01, 0.04
Not absolutely sure I have the right version as this was marked as a beta as I grabbed it on the 2nd
RT-AC3200_378.56_2.trx
but the Httpd appears to be stuck again after over 7.5 days, it was working last night for sure, about 12 hours ago but not I can not seem to connect to it. No problems getting into ssh and traffic currently looks fine. Trying to open a window to it never seems to time out, it just sits there from firefox and spins.
admin@RT-AC3200-36A0:/tmp/home/root# date
Wed Nov 11 09:22:27 MST 2015
admin@RT-AC3200-36A0:/tmp/home/root# free
total used free shared buffers
Mem: 255572 150860 104712 0 1500
-/+ buffers: 149360 106212
Swap: 0 0 0
admin@RT-AC3200-36A0:/tmp/home/root# ping -q -c 100 google.com
PING google.com (209.116.186.226): 56 data bytes
--- google.com ping statistics ---
100 packets transmitted, 100 packets received, 0% packet loss
round-trip min/avg/max = 3.511/4.292/8.735 ms
Anything I can do to give you more information ? No urgency to reboot at this time as it seems to be handling traffic fine, just can't connect via http.
It's a RT-AC3200 connected to a microwave 30mb up/down internet link. It has a 5tb usb3 disk plugged into it and all 4 lan ports are connected. There are two other ASUS routers acting as AP's, a AC66 and an AC68 both running a copy of 378.56_2 from yesterday when I updated them.
you can see httpd is hung with netstat
11:12:34 up 7 days, 17:53, load average: 0.00, 0.01, 0.04
admin@RT-AC3200-36A0:/tmp/home/root# netstat
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 1266 0 router.asus.com:www 172.16.2.124:63676 CLOSE_WAIT
tcp 0 0 router.asus.com:50861 172.16.2.15:netbios-ssn ESTABLISHED
tcp 1 0 router.asus.com:44266 172.16.2.120:7676 CLOSE_WAIT
tcp 0 0 router.asus.com:40029 172.16.2.16:8200 ESTABLISHED
tcp 0 0 router.asus.com:ssh 172.16.2.124:56916 ESTABLISHED
tcp 0 0 router.asus.com:50724 172.16.2.20:34486 ESTABLISHED
tcp 1349 0 router.asus.com:www 172.16.2.124:1248 ESTABLISHED
tcp 168 0 38.75.230.176:www 172.16.2.124:2525 CLOSE_WAIT
tcp 1350 0 router.asus.com:www 172.16.2.124:63680 CLOSE_WAIT
tcp 1350 0 router.asus.com:www 172.16.2.124:2767 CLOSE_WAIT
tcp 0 0 router.asus.com:59909 172.16.2.20:34486 ESTABLISHED
tcp 0 0 router.asus.com:57026 172.16.2.16:8200 ESTABLISHED
tcp 1288 0 router.asus.com:www 172.16.2.124:63657 CLOSE_WAIT
tcp 1 0 router.asus.com:www 172.16.2.124:63656 CLOSE_WAIT
tcp 0 0 router.asus.com:38349 172.16.2.20:34486 ESTABLISHED
tcp 167 0 38.75.230.176:www 172.16.2.124:1161 ESTABLISHED
tcp 1280 0 router.asus.com:www 172.16.2.124:63686 CLOSE_WAIT
tcp 1282 0 router.asus.com:www 172.16.2.124:63660 CLOSE_WAIT
tcp 0 0 router.asus.com:41793 172.16.2.20:34486 ESTABLISHED
tcp 1280 0 router.asus.com:www 172.16.2.124:4403 CLOSE_WAIT
tcp 1270 0 router.asus.com:www 172.16.2.124:63678 CLOSE_WAIT
tcp 0 0 router.asus.com:netbios-ssn 172.16.2.124:1043 ESTABLISHED
tcp 1 0 router.asus.com:56907 172.16.2.120:7676 CLOSE_WAIT
tcp 1279 0 router.asus.com:www 172.16.2.124:63679 CLOSE_WAIT
tcp 1285 0 router.asus.com:www 172.16.2.124:63659 CLOSE_WAIT
tcp 0 0 router.asus.com:56711 172.16.2.16:58248 ESTABLISHED
tcp 0 0 router.asus.com:46691 172.16.2.20:34486 ESTABLISHED
tcp 1 0 router.asus.com:57292 172.16.2.120:7676 CLOSE_WAIT
tcp 0 0 router.asus.com:54864 172.16.2.16:8200 ESTABLISHED
tcp 1280 0 router.asus.com:www 172.16.2.124:3191 CLOSE_WAIT
tcp 310 0 router.asus.com:www 172.16.2.124:1138 ESTABLISHED
tcp 0 0 router.asus.com:37385 172.16.2.20:34486 ESTABLISHED
tcp 0 0 router.asus.com:38085 172.16.2.16:8200 ESTABLISHED
tcp 0 0 router.asus.com:51055 172.16.2.20:34486 ESTABLISHED
tcp 0 0 router.asus.com:8200 172.16.2.16:51591 ESTABLISHED
tcp 1287 0 router.asus.com:www 172.16.2.124:63658 CLOSE_WAIT
tcp 1298 0 router.asus.com:www 172.16.2.124:63661 CLOSE_WAIT
tcp 0 0 router.asus.com:59209 172.16.2.16:8200 ESTABLISHED
tcp 1266 0 router.asus.com:www 172.16.2.124:63677 CLOSE_WAIT
tcp 0 0 router.asus.com:51789 172.16.2.16:8200 ESTABLISHED
tcp 1 0 router.asus.com:38830 172.16.2.120:7676 CLOSE_WAIT
tcp 311 0 router.asus.com:www 172.16.2.124:2504 CLOSE_WAIT
tcp 0 344 router.asus.com:ssh 172.16.2.124:1255 ESTABLISHED
tcp 1 0 router.asus.com:60226 172.16.2.120:7676 CLOSE_WAIT
tcp 1280 0 router.asus.com:www 172.16.2.124:4432 CLOSE_WAIT
tcp 0 0 router.asus.com:34416 172.16.2.20:34486 ESTABLISHED
tcp 0 0 router.asus.com:54715 172.16.2.15:netbios-ssn ESTABLISHED
tcp 0 0 router.asus.com:40885 172.16.2.16:8200 ESTABLISHED
tcp 0 0 router.asus.com:34282 172.16.2.20:34486 ESTABLISHED
tcp 1 0 router.asus.com:59679 172.16.2.120:7676 CLOSE_WAIT
tcp 0 0 router.asus.com:netbios-ssn 172.16.2.124:53662 ESTABLISHED
tcp 0 0 router.asus.com:41185 172.16.2.16:8200 ESTABLISHED
tcp 1350 0 router.asus.com:www 172.16.2.124:64085 CLOSE_WAIT
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 8 [ ] DGRAM 358 /dev/log
unix 2 [ ] DGRAM 2023184
unix 3 [ ] STREAM CONNECTED 1249174
unix 3 [ ] STREAM CONNECTED 1249173
unix 2 [ ] DGRAM 1994
unix 2 [ ] DGRAM 1379
unix 2 [ ] DGRAM 1349
unix 2 [ ] DGRAM 1045
unix 2 [ ] DGRAM 361
any way to restart it ?
UPdate: RT-AC3200 started acting erratic, so rebooted it. upgraded firmware to known release of 56_2 and rebooted again. 11/11/15 18:15 mst
Everything is now working again
