change tx-power
smeegul
Hi everyone! bought a router Asus RT-AC1200 V2, I can't find a tx-power change. Can I tell you how to change tx-power?
Check the bottom of the Wireless - Professional page. If it's not there then you can't change it on that model.
Is it possible to change tx-power via the ssh command line?
Try entering this command via SSH and seeing if it shows you anything:
nvram show | grep wl._txpower
Your router has completely different hardware and firmware than mine so that command might not work.
size: 25562 bytes (35878 left)
wl0_txpower=100
wl1_txpower=100
Try setting the power (for 2.4GHz and 5GHz respectively) to 50% as follows:
nvram set wl0_txpower=50
nvram set wl1_txpower=50
nvram commit
Then reboot the router to try and apply that change.
After rebooting see whether the values are still set by running the same command as before:
Thanks, it worked out.
size: 25491 bytes (35949 left)
wl0_txpower=50
wl1_txpower=50
