All,
So I am switching from Spectrum Cable 400/25 Internet to AT&T Fiber 1Gb Internet.
Before the change I was only getting close to 400MB at my laptop which was hard-wired to a NETGEAR GSS116E Switch in the office that was wired to the AX-88U in the server closet.
I then had to change that Netgear out and move it to another room and I changed it to a D-Link 5 port gigabit switch in the office. At that point, my speed dropped to mid 300's so I figure the D-Link can't handle traffic even though it is a Gigabit switch.
Fast forward a little to yesterday, I installed the fiber modem and re-configured the setup. I was still only pulling mid-300s down from the laptop, but I was getting close to 950MB upload speed... which I found REALLY ODD.
I was going to buy a new 8 port switch to replace the D-Link in case there was a bandwidth issue here, but also on occasion while testing it would go to 650 MB download speed but it would not be consistent. Actually I ran one while writing this and it was 612 down and 941 up from the laptop...
I installed the spnMerlin test on the router, and while I have heard that the router may not give the best results running from it directly, I am getting over 900MB down on each test (min 914, max 933), but upload speeds are only about 600MB.
My latency is MUCH better with the fiber, where I was getting up to 14ms with spectrum I am all the way down to 3 on the fiber with very little jitter.
Of course if I run it from my phone S20 Ultra, using the AC Wi-Fi 6 connection its awful at only 82 down and 48 up, but I expect that from the phone.
Since this is all over the place I don't know what results to actually believe. Is the download from the router correct, is the upload from the laptop correct, is it some combination of the two?
I want to get this dialed in while I am in my trial period with AT&T to make sure everything is working as it should in case I need to cancel.
Thanks in advance,
Nathan
Thanks in advance,
Nathan
