Thank you for that. I can increase the 2.4ghz to 200mW now.
I thought I was going crazy that I could set up to 500mW before but I guess as you say they changed the firmware. The validation is probably just I the webform so it can probably be overridden somewhere.
Surprisingly changing the web interface has appeared to modify the power (here: http://forums.smallnetbuilder.com/showthread.php?t=9986).
Although I've probably broken a whole bunch of EU laws though ...
Here is a thread on the subject by super router programmer Toastman:
http://www.linksysinfo.org/index.php?threads/tomato-signal-strength-low-any-ideas.33868/
In brief, the US country regulation is a boolean variable that cancels out any and all modifications of the transmit power you make.
Solution: Change country to Singapore and boost away. (Tomato only I think) Although it would appear with the e3000 that it is a case of diminishing returns as you up the power. YMMV
Souce: Not me
Higher output = increased radio noise? I would say it is quite the opposite. Could you please supply some references?Higher output would mean a little more range but at the cost of increased radio noise, and subsequently lower throughput, so you could actually cut performance across the board by increasing the power output.
There is no EU law that restricts WiFi transmit power, so you can legally set whatever you want.
The only limit is on ERP, so you just need to use the power setting with an appropriate antenna....
What is the factory default value for transmit power on the 2 bands of the RT-N66U? I've changed it a few times and lost track of the default. Thanks.
Welcome To SNBForums
