Channelizing
Diveblaster
Hi
I got a question about having different normal/guest networks both on 2.4 and 5 GHz. Is it possible to change default network channel or does the router do that automaticly.
AC66U (Latest merlin build)
Regards Dive
The Guest and Primary network SSID's are on the same channel as they're shared on the same radio (both for 2.4 and 5GHz).
