Cisco SOHO97 Router problem
B
bfisher
Guest
I have the router as listed in the title. However upon inserting the ethernet cable it does not establish a connection between the router and pc, and continually has "acquiring network connection" or similar as the status on the computer until it goes to limited connection status.
I have tried setting a static ip address, however I still cannot seem to access the router at it's default address as well as other suggested addresses I have found on the internet.
I purchased it off someone else, who will not give me any support and said that it was working fine on his network. It did not come with a manual, although I have found some information similar on the net to help, but have not come at a solution. I have tried multiple computers.
Default address for this router is 10.10.10.1 as found on cisco website.
Would appreciate any help.
The obvious stuff:
Verify you're not cabled into the console port;
make sure the configured subnet matches with the router.
If that doesn't work, use your terminal of choice (putty, hyperterminal, etc) to access it via console, to find out if the unit has bricked.
Thanks jdabbs.
The obvious stuff:
Not plugged in console port.
Pretty sure the subnet is right when I try manually configuring the ip.
I plugged it in this time and got assigned an "automatic private address" with the computers ip the same as the gateway. Can't access the router though.
I tried pinging the range of ip addresses that the router might be in (while on a static ip) if it's not at the default ip, but no response.
Do I need a special cable to plug into the console port? And can I just plug it into my computers' network adapter on the other end? (Edit: Assuming you access the console via the console port?)
I found a console cable here, is this what I need? http://www.trademe.co.nz/Computers/Cables/Networking/auction-171266997.htm
If you're certain about the IP/subnet, ok.
A console cable was included as an accessory, but since you're getting it second hand, you probably wouldn't have gotten it. It's a Serial to RJ-45 cable, on eBay you can get one for less than $4 shipped (USA).
I'd try switching to another of the LAN ports just to rule out that it isn't just a bad port. Additionally, I'd ask the seller (assuming previous owner) if he reset the device before giving it to you. It looks like this device is IOS based; if it is even possible to perform a reset, there is a possibility that a reset would delete the config instead of just overwriting it with a default one.
Edit: That's the correct cable.
I've tried different ports on the router.
He said he wiped the config, but I'm not sure if that's the same as a reset?
If he wiped the config and that means that it deleted the config, does that mean I'll have to configure it from scratch?
I don't know for certain. With "real" Cisco routers (IOS-based), erasing the config leaves you at setup mode w/ no config. This is a very silly decision to implement on a consumer device. The inclusion of a console port and IOS does indicate this is a plausible scenario. Without being able to check by consoling in, it's hard to say.
Ok. I'll get back to you once I've got the console cable. The seller said he could provide me with one which I will pick up later today. Thanks for your help.
Edit: Where can I find out how to use the console on the router? etc. I think all I need to do is perhaps set up DHCP so that I can get an address when I plug in my computer, and anything else that needs to be configured. I think it has a web interface I could use from there. If it doesn't it could be a bit more complicated.
Configuring an interface shouldn't be too difficult. If you post your config, I'll provide the commands for copy/paste usage.
Cisco devices require the following parameters: 9600 (baud) 8 (data bits) N(o parity) 1 (stop bit). If you reboot the device while a session has been established, the boot progress will be displayed.
Once you're in and the device is ready:
You'll be prompted to enter setup mode or hit enter to access user mode.
Assuming no setup mode and no console password in place:
enable
show run
*copy the data down to paste here. redact passwords and/or hashes, if present*
Since my internet connection was down while I was switching isps, I tried configuring it myself using the initial setup. However, although the setup went through fine and saved, and although I can still access the router ok in console, it now comes up with these error messages in the terminal while using it:
%Error opening tftp://255.255.255.255/home-confg (Timed out)
*Mar 1 00:08:55.743: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/home-confg) failed
%Error opening tftp://255.255.255.255/home.cfg (Timed out)
*Mar 1 00:09:33.747: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/home.cfg) failed
Should I reset the router back to default settings before continuing? How do I do that?
Here is the config:
home#show run
Building configuration...
Current configuration : 1028 bytes
version 12.3
service config
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname home
boot-start-marker
boot-end-marker
enable secret {----}
enable password {----}
ip subnet-zero
no ip routing
no aaa new-model
no crypto isakmp enable
interface Ethernet0
ip address 10.10.10.1 255.255.0.0
no ip route-cache
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip classless
ip http server
no ip http secure-server
snmp-server community public RO
snmp-server enable traps tty
control-plane
line con 0
exec-timeout 0 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
password {0----------}
login
transport input all
scheduler max-task-time 5000
end
This is the config after I did the initial setup
The TFTP error message is the router unsuccessfully attempting to grab a config.
By "using initial setup", are you referring to setup mode, or the web-based config?
If the former, you should be able to access the web-based one now by connecting to the LAN port, using a static IP of 10.10.10.2 w/ subnet mask of 255.255.0.0. I'd take a look at what utilities are offered there first before rebuilding the config.
Ok, I accessed the web interface, reset to defaults, built the config, and then set up the settings in the web interface.
I get an IP address with my ISP, but I can't actually access the internet at all. Strange. Any ideas?
First thing I'd check is whether you're still using the static IP, which doesn't have a gateway configured. If that's not the case, post the config to see how/if routing is configured.
Static IP? For the adsl or for my ethernet connection?
I am getting the address for my computer via dhcp now, and adsl connection is getting a dynamic address as well.
Here's my config:
Current configuration : 3267 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname {---------}
boot-start-marker
boot-end-marker
no logging buffered
enable secret {------------}
enable password {----------------}
ip subnet-zero
no ip routing
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
import all
network 10.10.0.0 255.255.0.0
default-router 10.10.10.1
lease 0 2
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
no aaa new-model
interface Ethernet0
ip nat inside
no ip route-cache
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
no ip mroute-cache
atm vc-per-vp 128
pvc 0/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
pvc 0/100
interface Dialer1
ip address negotiated
ip access-group 111 in
ip nat outside
ip inspect myfw out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname {----@---------}
ppp chap password {---------------}
ppp pap sent-username {-----@----------}
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip nat inside source list 102 interface Dialer1 overload
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 102 permit ip 10.10.0.0 0.0.255.255 any
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any traceroute
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 permit udp any eq domain any
access-list 111 permit esp any any
access-list 111 permit udp any any eq isakmp
access-list 111 permit udp any any eq 10000
access-list 111 permit tcp any any eq 1723
access-list 111 permit tcp any any eq 139
access-list 111 permit udp any any eq netbios-ns
access-list 111 permit udp any any eq netbios-dgm
access-list 111 permit gre any any
access-list 111 deny ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
password {------------------}
login local
length 0
transport input all
end
Thanks again for your help jdabbs.
I'll be away for a few days. I'll check again here when I'm back.
I'm actually still here until the end of the day (about 6-7 hours) if you want to suggest something jdabbs. Thanks.
Ah, ok. I'll grab a bite to eat, but I'll be around for most of tonight as well.
I've yet to come across DSL in the field so I can't do a true comparison, but I think with a bit of prodding the problem will be revealed.
Looks like routing is handled via a static route out Dialer0; sh ip route should confirm this. NAT also looks good. To find out if it's a routing issue, can you:
from the router:
ping 4.2.2.2
from PC command prompt:
ping the dynamic IP assigned by your ISP (should be bound to Dialer1),
tracert 4.2.2.2.
I don't know how your router is handling DNS: is it passing your ISPs DNS server IPs to the client via DHCP, or is it acting as an intermediary?
sh ip route reveals:
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
It looks like some of the routing table output is missing. No S or C routes were reported?
Dialer1 is configured as the static route ip route 0.0.0.0 0.0.0.0 Dialer1, is it not reported as such because the interface is down? sh ip int b displays ths info.
I actually didn't have the phone cable plugged in or anything.
I tried to access the web interface, but while I can access the router, it doesn't seem to be able to load the web interface, takes a long time looking for IOS settings etc., but then says that it cannot communicate with the router, although I got that far OK.
I would do a reset again, but not sure how to do that via the console.
It does come up with:
%NAT: Error activating CNBAR on the interface Ethernet0
þNAT: Error activating CNBAR on the interface Dialer1
during boot, not sure if that's related or not. Seems suspicious to me...
sh ip int b comes up with:
Interface IP-Address OK? Method Status Protocol
ATM0 unassigned YES NVRAM down down
Dialer1 unassigned YES NVRAM up up
Ethernet0 10.10.10.1 YES NVRAM up up
Virtual-Access1 unassigned YES unset up up
I'm not sure, what's the difference? I've got some idea, but it would help to explain.
DNS:
Imagine for a moment that your ISP's DNS server is 4.2.2.2 (Verizon). If your router was acting as an intermediary, the client would receive a DHCP lease with the router itself as the DNS server. If DNS info was just passed along, the client would receive a lease with a DNS server of 4.2.2.2. The reason I asked was because of wishful thinking on my part--there was a possibility that the router was configured correctly (previously stated it was able to obtain a dynamic IP) and that the client just needed a little tweaking.
Deleting the config:
There are two configs: the one in use residing in memory (running-config), and the one in NVRAM (startup-config). Performing an erase start in enable mode deletes the stored one, and power cycling the device immediately afterward gets rid of the one in memory.
NAT:
That may be a sign of a larger problem, but as NAT maps private IPs+ports to public, it is possible that if there is no public IP to map to, error messages may be generated. This is increasingly likely upon initial bootup.
And to clarify, are you using a config generated by setup mode, or one provided by the web interface/software CD?
