CLI AiMesh RT-AX92U force sync
SDoo
I found a lot of information on SNB, it was very helpful.
But still a small thing I didn't found...
I can enable a Guest network on the AiMesh router by using CLI - telnet: nvram set wl0.1_bss_enabled=1
But then it is only enabled on the router, not on the nodes. When using the web or app, it does sync to the nodes, so I know it can work.
Should I send a command.... sync the new settings to the nodes? And if so... what should it be?
Commands found/used, maybe helpful for others:
nvram get wl0.1_bss_enabled
nvram set wl0.2_ssid=MYNEWSSID
nvram commit
service restart_wireless
nvram show | grep ssid (replace SSID with other words to know more)
I can explain the goal. I need an external trigger to trigger the guest network on / off.
It will probably in the end be a physical button that will turn on/off the guest network.
I can make a physical button send out SSH. Meaning I can make a -press this button to enable (or disable) the guest network.
But it should sync to the nodes. Inside the web-page of ASUS it works. Also on the iOS App. I just don't know the command it is sending out, so I can copy it into pure SSH.
The website mentions: create_guest_unit(2,1);
