Today I use a D-Link DIR-855 in my livingroom connected to my broadbandconnection and with Ethernet to my HTPC, medialink and TV (yeah, DNLA on the TV ;-). In addition I have a HomePlug-connection with brings my network up to the second floor, where I have a Gigabit Ethernet-switch connecting sevral pc-s and a couple of NAS-units. On the NAS I also run HTTP/HTTPS- and SFTP-server through NAT.
Problem is that Homeplug is slow - it's slower than my broadbandconnection, and it gives me problems if a want to stream files to the HTPC or medialink and at the same time use my broadbandconnection to download something...
Overview of the setup at home can be found attached.
So I want to get rid of the Homeplug.... I need a new connection between the two floors in the house. Using a cable would have been the best naturally, but that is not a option here now (the rooms are in different ends of the house, and no channels in the walls for cables...)
So I want a solution where I have a wlan-router on the second floor making a connection with the first floor setup. From what I understand this should be possible through using Client Mode or WDS, or seting a router up as a wireless bridge. I also need sevral units being with is on a cabled connection available for all other devices in the network.
The D-Link DIR-855 I have don't support Client Mode and don't support WDS. A solution could have also been to buy a WLAN-to-Ethernet-bridge, but don't find anyone that have one with 802.11n-support.
I have a Linksys WRVS4400N and a WRT160N also laying here, and the question is then if/how I could have used these. I have powered them up here, but can't find any info in the admin-interface or in the product info if these support WDS or Client mode. And if so, how can it be set up? If one them support Client Mode, I guess I could use it against the D-Link DIR-855 which is allready set up (kinda strange that the DIR-855 don't have features the old DIR-655 had...)
Suggestions?
Suggestions?
