Sorry I'm trying my best to navigate OpenVPN guides under tomato and get this configured for my BT Guard account, and I have searched this forum every way I can think, but I'm still unsuccessful. I have the 246.19 merlin build.
This is the config file recommended by BT Guard for Linux - I assume that's the best starting point for for configuring the Open VPN client:
client
dev tun
proto tcp
remote vpn.btguard.com 1194
resolv-retry infinite
nobind
persist-key
persist-tun
ca btguard.ca.crt
;comp-lzo
verb 3
mute 3
auth-user-pass
mute-replay-warnings
float
reneg-sec 0
I've tried copying settings others recommend, I've also tried just pasting this into the config section at the bottom, but I receive error "unrecognized option or missing parameter." I see there are duplicates in this list with the GUI config option above. So I guess my question:
1. Is there a link someone has I can follow that will help me get setup with BT Guard. I don't want to wasted anyone's time if it's readily available on the net.
2. If not, should I take the configuration here and implement that above? Would I have some of the options I cannot find above left in the Custom Configuration settings?
3. Or do the custom configuration settings overwrite?
Finally I am not locked to BTguard, but it just seems in my research they are one of the more secure out there. If there are other options that are equal or greater with anonymity / security that would allow me to config this router easier please shoot me straight.
Thanks!
client
dev tun
proto tcp
nobind
persist-key
persist-tun
ca btguard.ca.crt
;comp-lzo
verb 3
mute 3
auth-user-pass
float
reneg-sec 0
Thanks!
