I have an ASUS GT-AX6000 running on the latest stable version of Merlin. The router is configured as a DHCP server and, the DNS server is configured to be a pi-hole instance running on a mini PC.
Not sure why but, even if everything is correctly configured, the router is querying the DNS server. As a matter of fact, the Router is by far the most active client of the DNS server.
Not a biggie, afer all, if the router is acting as a DNS server but relies on pihole, unwanted traffic is still being blocked and pi-hole is not being bypassed .
But I am wondering why and what can I do to check which client is using the router as the DNS server. Is there a way perhaps with some logs ?
DNS is set under LAN -> DHCP Server -> DNS and WINS Server Setting
PIHole IP address is "Manually Assigned IP around the DHCP list" under LAN -> DHCP Server
Under WAN -> inernet connection -> WAN DNS Setting, the DNS Server as set to be Google (not pihole)
thanks in advance.
thanks in advance.
