I'm just here reviewing the cloud station feature on the Synology NAS, currently I'm working in the field of IT and I know, from working with people, especially in the field of IT, dropbox has become over the last 4 years or so a very common tool used by so many people. And from my point of view, it is one of the handiest features around for keeping data in the cloud, simply either for backing up files or for just accessing them on your devices. People regularly bring up the word 'dropbox' in a conversation, I am now commonly mentioning 'cloud station', which is, my person dropbox, and many seem very interested in it and here I am writing an review of the features, for those people who ask what is it?, what does it do?, how does it work?, and how do I get it?
Cloud station is simply dropbox, just while using your own hard drive as the cloud. This has many added features, cheap unlimited data (to whatever you can fit in your NAS), and no monthly fees (aside from your internet connection, which is usually very large these days anyway). On the client side, the apps are available on the usual list of devices (iOS, Mac, Windows, Android, Windows Phone), and it works pretty much the same way as dropbox, as it syncs files on your computer to the cloud, and lets you access them on your all your devices.
Below is the iOS app for Cloud Station:
A few extra features to mention is the Recycle Bin, which does what it says. When you delete a file, the file gets moved into a hidden folder, and can only be access from the NAS UI, from there the file can be emptied or restored. Another feature is the ability to have multiple users, as many as you want. This allows you to share folders between the users, and allow them to have there own folder share.
Below is the UI manager inside the Synology DSM:
It's simple, quick and easy to setup, as with pretty much everything. Synology has packaged it quite nicely, and It works really well, as how it should. Cloud station can only be installed on a Synology NAS, but its definitely worth trying it out, and its a great replacement for dropbox.
