Comm: roamast Tainted: P O 4.1.52 #1 - SIGSEGV
jackc88
Would you anyone know if it is possible to prevent roamast from launching, or recover from a crash?
service restart_net_and_phy and reboot didn't seem to work. I had to power-cycle the modem.
I realized the crash last night stopped routing to the Internet. I have seem these crashes before and usually the router continues working. I turned off roaming. It crashed again today. I turned off Smart Connect and the process still launches and crashed. Any help would be appreciated.
I have also been having drama the last week or so with Xfinity/Comcast. If there is any interest, I can open up a post here as well. Xfinity Internet - LoS ( Provisioning and DHCP ) FYI, if anyone runs into the same issue, you can stop the script udhcpc kicks off when ISP's DHCP misbehaves in the interim. This will at least stop the connection from going down when /sbin/rc kicks off. I am considering running ISC's dhclient to see if I can get some different logs if need be.
RT-AX58U on 386.1_2
Third Crash:
potentially unexpected fatal signal 11.
CPU: 1 PID: 24082 Comm: roamast Tainted: P O 4.1.52 #1
Hardware name: Generic DT based system
task: d4538c00 ti: ce97e000 task.ti: ce97e000
PC is at 0x103a0c
LR is at 0x10fdf8
pc : [<00103a0c>] lr : [<0010fdf8>] psr: 20000010
sp : beed6570 ip : 00000000 fp : 00b7c4a0
r10: 001a0000 r9 : 001d51c8 r8 : 00000000
r7 : 00000000 r6 : 001d4d94 r5 : 001d52a0 r4 : 001a0000
r3 : 00000000 r2 : 00000000 r1 : 00b7c4a0 r0 : 00000001
Flags: nzCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
Control: 10c5387d Table: 0ea3804a DAC: 00000015
[<c0026e60>] (unwind_backtrace) from [<c0022c38>] (show_stack+0x10/0x14)
[<c0022c38>] (show_stack) from [<c044e31c>] (dump_stack+0x8c/0xa0)
[<c044e31c>] (dump_stack) from [<c003aacc>] (get_signal+0x490/0x558)
[<c003aacc>] (get_signal) from [<c00221d0>] (do_signal+0xc8/0x3ac)
[<c00221d0>] (do_signal) from [<c0022658>] (do_work_pending+0x94/0xa4)
[<c0022658>] (do_work_pending) from [<c001f4cc>] (work_pending+0xc/0x20)
CFG80211-ERROR) wl_cfg80211_event : ignore event 12, not interested[/CODE]
