For the Quantenna SoC:
Code:qcsapi_sockrpc get_temperature
For the Broadcom CPU:
Code:cat /proc/dmu/temperature
No more showing the Bios system page ?
Before we go any further:Hello ,
In official software , how can we open command line ? please explain.
I login with SSH and putty , but it doesn't show .
Did you enable SSH on the "Administration|System" page?
It all depends on ambient temperature. Yesterday was a hot day here and my AC68U cpu (clocked to 1200) reached 86ºC with a room temp of 29ºC. Usual temps these last days have been around 77ºC.HI Merlin,
First of all, thanks for the firmware work on the 87U, it's appreciated, I am sure, by the entire 87U community!
What's the normal operating temp for the 87U? I am very concerned that mine is showing this:
Uptime 0 days 22 hours 41 minutes 58 seconds
Temperatures 2.4 GHz: 46°C - 5 GHz: 69°C - CPU: 84°C
That's 84°C is really very hot! It can't be normal can it?
I don't have much going on in the router at the moment, and yet it's at that temp. I don't have NAT switched on, (as I have a perimeter router doing that), and firewall is also off. All the QOS stuff is also off. Room ambient temp is around 28°C.
The rest of the details:
CPU
CPU Model ARMv7 Processor rev 0 (v7l) - (Cores: 2)
CPU Frequency 1000 MHz
CPU Load Average (1, 5, 15 mins) 0.24, 0.07, 0.06
Memory
Total 249.76 MB
Free 179.14 MB
Buffers 3.07 MB
Swap usage 0.00 / 0.00 MB
Internal Storage
NVRAM usage 38498 / 65536 bytes
JFFS 1.73 / 62.75 MB
I have similar temps on both DD-WRT as well as Merlin's latest firmware. I settled on Merlin firmware as DD-WRT is just too buggy and breaks too many things.
Merlin firmware details:
Model RT-AC87U
Firmware Version 378.53
Firmware Build Mon Apr 27 02:38:26 UTC 2015 merlin@c5ef2ea
Bootloader (CFE) 1.0.3.2
Driver version wl0: Mar 12 2015 16:56:18 version 6.37.14.86 (r456083)
Quantenna Firmware v36.7.0.31
Appreciate your thoughts on this.
Thanks!
Anyway, make a search then you'll find several threads about this topic.
Sent from my Nexus 5 using Tapatalk[/QUOTE
Infrared image of RT-AC87U I try to upload raw file (you can download Fluke Smartview to view) but the forum refuses it for not valid file, so I upload simple exported JPG, if the Admin gives me away to share the raw file, I will re-upload.For the Quantenna SoC:
my 87u also have today 84C for CPU. Its normal temp.HI Merlin,
Thanks!
Why go through all that trouble (and void your warranty)? I have a mini USB laptop cooler under my AC87R and the CPU temp stays below 60°C, 5GHz temp stays under 53°C and the 2.4GHz temp runs from 38°-43°C. I bought 3 such fans for less than $13US on eBay out of China of course.Today I bought RT-AC87U and it showed CPU temp between 79-83°C. So, I started to google information about that issue and found this. As you can see on the photos, thermal paste don't cover the entire area of contact between CPU and radiator. If to re-apply thermal paste throughout the entire area of the compound - this may reduce the temperature slightly. Tommorow I'm planning to disassemble my ac87 and check thermal paste. I am also considering the option of dismantling the upper part of the ac87 and installing the fan xD
Welcome To SNBForums
