Complete bypass Ipad
Josweet
Im trying to completely bypass this ipad from diversion completely. I have tried setting the device in multiple different "filter mode" types but they are all still causing me one headache or another.
I originally set the filter type to "No filter" but still had issues with certaine sties not working even though they were whitelisted.
Latest is ITVHUB not working on the ipad.
Ill look into why im having issue's later, i just need to bypass it for now.
In most cases just using LAN > DHCP Server : Manually assign IPs around the DHCP List
will work - yes you have to assign the device an IP, but you can also assign it a DNS to use. Note that after doing this you will need to have the device use that new DHCP info (or it may not work it immediately).
*DNS Filter is fine, but it works a different way and often isn't necessary!
**ITV Player is usually much more cooperative than BBC iPlayer!
You may look at the link below on how to exclude devices from diversion adblocking.
By the way, which blocking list are you using? Perhaps you are using a too aggressive blocking list that causes the issue. A quick way is to check your blocking list.
Alternatively, if you want to dig further to find out what is being block and figure out what to whitelist manually for your application to run, you can go to diversion main menu, use "f" to follow the dnsmasq log files. You can choose to show only your ipad ip address and blocked domain, then run your application. This way, you can easily see what are being blocked and you can later whitelist it one by one to identify the culprit.
F Skynet Skynet - Single Device Bypass on LAN Asuswrt-Merlin AddOns 1
