LogicalRon
I'm building a new house and want to run my cat6 before they drywall. I plan to run extra cable to each possible box and even some walls that I may use in the future. I trying to decide if I should spend the extra cost of using conduit or just run the cable and you the nail in plastic holders ( wire clips ) to hold the cable in place. I'm doing this either with the electrician or after he is done so I can keep the cat6 the proper distance fro the electrical wires.
Any thoughts or advice that would be helpful to me would be very much appreciated. I'm aware of keeping the bends proper and feel that would be easier without conduit?
Any input is helpful
Thanks in advance
Thanks in advance
