Type dmesg to see what the USB-to-serial driver is not loading. It would be /dev/ttyUSB0, for example.
ASUSWRT-Merlin RT-AC66U_3.0.0.4 Mon Nov 2 14:59:04 UTC 2015
admin@RT-AC66U-9EE8:/tmp/home/root# dmesg
start_kernel
Linux version 2.6.22.19 (root@asus) (gcc version 4.2.3) #1 Mon Nov 2 09:59:58 EST 2015
CPU revision is: 00019749
Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Determined physical RAM map:
memory: 07fff000 @ 00000000 (usable)
memory: 08000000 @ 87fff000 (usable)
On node 0 totalpages: 589823
Normal zone: 1024 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 130048 pages, LIFO batch:31
HighMem zone: 3583 pages used for memmap
HighMem zone: 455168 pages, LIFO batch:31
Built 1 zonelists. Total pages: 585216
Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 2048 (order: 11, 8192 bytes)
CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Using 300.000 MHz high precision timer.
console [ttyS0] enabled
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 238352k/131068k available (2667k kernel code, 22808k reserved, 532k data, 200k init, 131072k highmem)
Calibrating delay loop... 299.82 BogoMIPS (lpj=1499136)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
PCI: Initializing host
PCI: Reset RC
PCI: Reset RC
PCI: Fixing up bus 0
PCI/PCIe coreunit 0 is set to bus 1.
PCI: Fixing up bridge
PCI: Setting latency timer of device 0000:01:00.0 to 64
PCI: Setting latency timer of device 0000:01:00.1 to 64
PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
PCI: Fixing up bus 1
PCI/PCIe coreunit 1 is set to bus 2.
PCI: Setting latency timer of device 0000:02:00.0 to 64
PCI: Setting latency timer of device 0000:02:00.1 to 64
PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
PCI: Fixing up bus 2
NET: Registered protocol family 2
Time: MIPS clocksource has been installed.
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
highmem bounce pool size: 64 pages
squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
io scheduler noop registered (default)
HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
N_HDLC line discipline registered.
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a 16550A
serial8250: ttyS1 at MMIO 0x0 (irq = 8) is a 16550A
PPP generic driver version 2.4.2
MPPE/MPPC encryption/compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V0.18.3
PPTP driver version 0.8.5
pflash: found no supported devices
Boot partition size = 262144(0x40000)
Creating 2 MTD partitions on "sflash":
0x00000000-0x00040000 : "pmon"
0x001f0000-0x00200000 : "nvram"
Found a Zentel NAND flash with 2048B pages or 128KB blocks; total size 128MB
lookup_nflash_rootfs_offset: offset = 0x0
nflash: squash filesystem with lzma found at block 9
Creating 2 MTD partitions on "nflash":
0x00000000-0x02000000 : "linux"
0x0013d26c-0x02000000 : "rootfs"
NAND device: Manufacturer ID: 0x92, Chip ID: 0xf1 (Zentel NAND 128MiB 3,3V 8-bit)
Bad block table found at page 65408, version 0x01
Bad block table found at page 65344, version 0x01
nand_read_bbt: Bad block at 0x07fe0000
Creating 3 MTD partitions on "brcmnand":
0x00000000-0x02000000 : "trx"
0x02000000-0x04000000 : "jffs2"
0x04000000-0x07f00000 : "brcmnand"
dev_nvram_init: _nvram_init
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
u32 classifier
OLD policer on
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
net/ipv4/netfilter/tomato_ct.c [Nov 2 2015 09:59:57]
ipt_account 0.1.21 : Piotr Gasidlo <
quaker@barbara.eu.org>,
http://code.google.com/p/ipt-account/
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <
greearb@candelatech.com>
All bugs added by David S. Miller <
davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 200k freed
Warning: unable to open an initial console.
Failed to execute /sbin/preinit. Attempting defaults...
Algorithmics/MIPS FPU Emulator v1.5
ctf: module license 'Proprietary' taints kernel.
et_module_init: passivemode set to 0x0
et_module_init: et_txq_thresh set to 0xce4
PCI: Setting latency timer of device 0000:00:01.0 to 64
bcm_robo_enable_switch: EEE is disabled
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
wl_module_init: passivemode set to 0x0
PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
PCI: Setting latency timer of device 0000:01:01.0 to 64
eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
PCI: Setting latency timer of device 0000:02:01.0 to 64
eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.163.2002 (r382208)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
br0: starting userspace STP failed, staring kernel STP
vlan1: add 33:33:00:00:00:01 mcast address to master interface
vlan1: add 01:00:5e:00:00:01 mcast address to master interface
vlan1: dev_set_promiscuity(master, 1)
device eth0 entered promiscuous mode
device vlan1 entered promiscuous mode
device eth1 entered promiscuous mode
wlc_phy_cal_init_acphy: NOT Implemented
device eth2 entered promiscuous mode
br0: port 3(eth2) entering listening state
br0: port 2(eth1) entering listening state
br0: port 1(vlan1) entering listening state
br0: port 3(eth2) entering learning state
br0: port 2(eth1) entering learning state
br0: port 1(vlan1) entering learning state
vlan1: add 33:33:00:00:00:02 mcast address to master interface
br0: topology change detected, propagating
br0: port 3(eth2) entering forwarding state
br0: port 2(eth1) entering forwarding state
br0: port 1(vlan1) entering forwarding state
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
SCSI subsystem initialized
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c027c000
NTFS (with native replay) support included
optimized: speed
Build_for__asus_n66u_2011-10-27_U86_r187446_b122
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
PCI: Setting latency timer of device 0000:00:04.1 to 64
ehci_hcd 0000:00:04.1: EHCI Host Controller
ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
PCI: Setting latency timer of device 0000:00:04.0 to 64
ohci_hcd 0000:00:04.0: OHCI Host Controller
ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:04.0: irq 6, io mem 0x18009000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usb 1-1: new high speed USB device using ehci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver rndis_host
cdc_ncm: 14-Mar-2012
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver qmi_wwan
cdc_mbim: loaded
usbcore: registered new interface driver cdc_mbim
usb 1-1.1: new full speed USB device using ehci_hcd and address 3
usb 1-1.1: configuration #1 chosen from 1 choice
usb 1-1.2: new high speed USB device using ehci_hcd and address 4
usb 1-1.2: configuration #1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
scsi 0:0:0:0: Direct-Access PNY USB Flash Drive 1100 PQ: 0 ANSI: 4
sd 0:0:0:0: [sda] 31299584 512-byte hardware sectors (16025 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI removable disk
sd 0:0:0:0: Attached scsi generic sg0 type 0
nf_conntrack_rtsp v0.6.21 loading
nf_nat_rtsp v0.6.21 loading
usb 1-1.1: USB disconnect, address 3
usb 1-1.1: new full speed USB device using ehci_hcd and address 5
usb 1-1.1: USB disconnect, address 5
usb 1-1.1: new full speed USB device using ehci_hcd and address 6
