crashnburn
Connect & Access across separate LAN Subnets in 2 Suites in a building?
Following is an older diagram of a 2+1 level Small Business/ Startup + Co-working space, with recent expansion & need for integration.
The following changes & information have been outlined:
2 CAT6 Networks/ LANs:
With Option A constraints, How can we Connect/ access across separate LAN Subnets in 2 Suites in a building?
- Level 3 & 4 LAN is integrated & maps off a Central Area (Green Area); which has the NAS
- ISP---WR1: Asus RT-N16 N Router w Tomato USB FW + HP ProCurve 24 GigE Managed SW + ... N/W Clients
- Considering adding a PfSense/ Sophos box around here in the future
- Level 5 is a separate; a simpler & sparser LAN; recent expansion and sub-let
- ISP---WR3: Netgear or D-Link Wireless N Router + ... N/W Clients
- The Stuff in Green box to the upper right titled 'Load Balance ISPs' does not exist; It was the original plan that was never implemented
- We plan to run CAT6 cable between Level 4 & 5, outside the building and maybe add some more cables + terminations, and maybe a Hub/ Switch inside Level 5 - This is open/ flexible for now
- We need to connect & give access to NAS & maybe MFC/ Printer/ Scanner from Level 6 LAN
- Option A: Level 5 clients have Limited access purely to NAS & MFC; not be able to use Level 4 ISP Bandwidth
- Option B: Level 5 & 4 clients be able to share/ switch over/ bond ISPs in some fashion?
- Network Partitioning
- Addressing
- Physical Connections & Hardware
- SubNets/ VLANs?
