mawu
Hi friends ,
small problem with my vpn connection.
If I connect my phone with VPN and scan network - I only see all VPN clients.
If I connect my phone only with WLAN and scan network - I only see all LAN clients / but no VPN client.
If I want to connect Synology A with Synolgy B over the VPN tunnel - both Synologys has to be connected to the VPN Server. In Explorer or windows I can`t connect to the synology 10.8.0.2 ...
I think in my ovpn-server is an option missing - ;-)
Can you please help me
THANK U
VPN Server:
THANK U
VPN Server:
daemon ovpn-server1
topology subnet
server 10.8.0.0 255.255.255.0
proto tcp-server
port 1194
dev tun21
txqueuelen 1000
ncp-disable
cipher AES-256-CBC
auth SHA512
comp-lzo adaptive
keepalive 15 60
verb 3
push "route 192.168.1.0 255.255.255.0 vpn_gateway 500"
client-config-dir ccd
client-to-client
duplicate-cn
push "dhcp-option DNS 192.168.1.1"
push "redirect-gateway def1"
tls-auth static.key 1
plugin /usr/lib/openvpn-plugin-auth-pam.so openvpn
ca ca.crt
dh dh.pem
cert server.crt
key server.key
script-security 2
up updown.sh
down updown.sh
status-version 2
status status 5
