Hello Everyone. New Here
I had a small question to ask you guys.
Is it possible to run my external high gain panel antenna plugged directly into my Asus RT-N16(has 3 external removable antennas) and broadcast the signal out?
My current set up is:
outdoor panel antenna > alfa 1000mw usb wifi adapter > computer(usb port) > Bridge Connection(through ethernal LAN port) > into asus router as Access Point.
Is it possible to bypass a ton of that and have the external plug directly into the asus router(either through usb or use 1 of the 3 external antenna ports ) and receive the signal through 1 antenna and broadcast it out with the other 2?
thank you
thank you
