wgetmerlin
Hey SNB.
Firstly thanks to Merlin!
I've had issues for the past few days with my VPN interface. The connection seems to stop for about 20/30 seconds as a result all devices can't connect to the requests they send. This happens every 2/3 hours. The Wifi/Ethernet is NOT dropping as I can easily access admin panel from wifi.
I have tried different VPN configs and the issue persists. I have checked logs and there is no disconnection/connection requests to the VPN. Only DHCP requests.
I've got the Asus RT-86U (merlin mod of course) which is running the latest build.
Things I have tried in addition is disable QoS since that's when it happened.
I'm only using UDP for the speeds (200 compared to 50 on TCP).
Any advice/guidance will help. I have tried tracert and ping to see if there is a request timeout, unfortunately not all packets seem to be in tact.
My MTU size is 1500 (recommended by ISP too)
