Josef Karlsson
Hi!
I have bought a new rt-ax58u router and i am having some issues with the connection to my chromecasts. The wifi itself works flawless, both in smart connect mode and with separate bands (2.4 & 5 ghz). But when i try to connect my chromecasts to the new wifi, i can only get as far as to the wifi setup/selection screen in the google home app. The chromecasts try to connect, but can't get access. I have tried connecting them to another wifi (mobile hotspot) aswell as a guest network created on the new router and that works fine aswell.
According to one of Google's tech support there is some built in AP isolation or other setting that i can't change and therefor the router is not compatible with Chromecast. Is this really the case? Attaching router settings. I have a password, but removed it for screenshot. I have updated the firmware on the router.
Thanks in advance for help/input!
