Recently I have been facing an issue with connections to specific sites resetting. Most sites works completely fine and throw no errors. Refreshing the page enough times also solves the issue.
I first started noticing the issue a couple weeks ago. At the time I was running the latest version of Merlin 380.70 but since it has been abandoned, I have reverted back to stock 3.0.0.4.382.50470, resetting the nvram whilst reverting. The issue still exists.
In multiple browsers across multiple devices I am noticing "connection reset" errors whilst downloading assets. I have narrowed it down to being the router at fault as plugging in the original, ISP supplied router resolves the issue.
I have trawled through the settings and I cant see anything obvious which might be causing the issue. There are no filters set up and parental controls are disabled.
Does anyone have any suggestions as to what might be causing it?
