Constant disconnecting
TT7
I'm using Merlin 376.49_5 on Asus RT-N66U and experiencing disconnection from the Internet every 10-15 min.
This is copy of the system log in case someone can figure it out.
Any help would be greatly appreciated.
This looks like a normal response sequence to actually loosing connection to the ISP. I'd double check/replace all the cables and try a different modem if you can.
Thank you john9527.
I already got new modem from my Internet provider and I replaced cables between modem and router and phone line cable from wall outlet to the modem.
Check if your modem loses its DSL sync. You might also want to have the ISP check your DSL signal for signs of noise or distance issues.
When technician came to replace modem he tested line too. Everything was OK. He still gave me a new modem and I replaced cables.
Today I downgraded router firmware to 372.31 and disconnecting problem was still there.
That probably eliminates router issues and I'll have to focus on the modem and DSL line.
