So I keep getting dropped connections, and started running a constant ping on some devices to get to the bottom of it. I keep getting random "request timeout" responses during constant ping on my devices. Some more so than others. I'm getting them on devices that are far away and going through 1 or two switches, and devices that are immediate and are legitimately hard wired right into the back of the router itself. I'm using an AC-88u. I actually replaced the router itself with a brand new one hoping that would fix it...however I backed up my settings from the old router and did a restore onto the new router. Which I agree...is a red flag. But I had zero issues with this on the old router until for some reason one of my POE switches went bad and died. And I tried to swap in a new one in the middle of the day, and ever since then I started having these issues. So obviously I thought it was the new switch that I swapped in...so I've tried three or 4 different switches in place of it, and I'm still having the issue.
Is there something that could get saved within the router like the adaptable firewall that could make it to the new router with a backup/restore that would be causing all these connection droputs and "request timeouts" when pinging?
