HarryMuscle
I tried adding a custom NVRAM key/value (that one of my scripts requires) to the router configuration file (.cfg file) so that it can be included whenever I do a configuration restore, however, it looks like that's not possible. Restoring a configuration file only seems to restore NVRAM values that the router knows about and it seems to ignore any custom NVRAM values added in the configuration file (btw, I'm using WRTSettings to edit the configuration file). So I'm wondering if there is an "official" script or config file on the JFFS partition where additional custom NVRAM keys/values should go in order to actually be added into NVRAM?
Thanks,
Harry
Thanks,
Harry
