Country block failing (probably due to missing ipt_set.ko)
Finalcut62
Hi there,
I'm on 380.64 and I've been spending the past few days getting this project going using ipset as the basis for blocking incoming connections. However, the script on the GitHub page fails and when I do a manual step by step of the script, it turns out
insmod ipt_set
fails with a
insmod: 'ipt_set.ko': module not found
error. I assume that's the reason why the iptable commands in the script all fail with an error of the sets being looked for are not found.
Can I manually install that ipt_set.ko mod?
Best,
Paul
If you use ARM router you need to start new modules. You don't say if you are on ARM/MIPS
For arm routers:
lsmod | grep "xt_set" > /dev/null 2>&1 || \
for module in ip_set ip_set_hash_net ip_set_hash_ip xt_set
    do
    insmod $module
done
This work with both arm/mips
ipset -v | grep -i "v4" > /dev/null 2>&1
if [ $? -eq 0 ]; then
       # old ipset
   ipsetv=4
   lsmod | grep "ipt_set" > /dev/null 2>&1 || \
   for module in ip_set ip_set_nethash ip_set_iphash ipt_set
   do
       insmod $module
   done
    else
    # new ipset
   ipsetv=6
   do
       insmod $module
   done
fi
And if you are on arm you need to change this to:
if [ "$(ipset --swap malware-filter malware-filter 2>&1 | grep -E 'Unknown set|The set with the given name does not exist')" != "" ]; then
