Create exception for: Vulnerability Protection
Pergola Fabio
Hi
i wanted to give my alarm system an update, it connects to somekind of url on a specific port, 1 sec later, got a mail from my router, that it blocked the device
How can i allow exceptions for that device?
thnx
Event number : 1
Alert type : Vulnerability Protection
Source : (192.168.0.215)
Destination : Security_System
RT-AC88U's AiProtection detected suspicious networking behavior and prevented your device making a connection to a malicious website (see above and the attached log for details).Suggested actions:
1. If you know that the cause of this attempted connection was a proprietary app or program and not a web browser, we recommend that you uninstall it from your device.
2. Ensure your device is up to time in all its operating system patches as well as updates to all apps or programs.
3. You should take this opportunity to check for, and install, any router firmware updates.
4. If you continue to receive such alerts for similar attempted connections, investigation into the cause will be necessary.
Meanwhile, rest assured that AiProtection continues to help keep you safe on the Internet.
strange, on that site it says its safe
I suppose that's better than not safe. Maybe try updating the Signatures in the router webUI... maybe that will make a difference.
OE
Ok, i can try that...
But is there a way to make an exception?
Sorry, I mis-posted earlier.
Find and try the "Manage White List" control/icon on the AiProtection - Malicious Sites Blocking page(?). At this point, you're sure the url is not malicious(?). :)
OE
its not a malicous site, its a two-way ips protection, dont see a whitelist there ;-)
Given this is presumably an infrequent update for your security system (that's ironic!), disable the AiProtection, perform the update (at your own risk), and re-enable the AiProtection... a manual exception! :)
Maybe future AiProtection signatures will not complain. I suppose you could also report the matter to Asus/TM.
OE
