Can anyone tell me how to create a user script? I tried to follow the wiki here (https://github.com/RMerl/asuswrt-merlin.ng/wiki/User-scripts) but without luck...
My goal is to have the swap file turn on anytime I reboot the router. I found instructions here:
https://mydevtutorials.wordpress.com/2014/01/10/how-to-activate-swap-on-asus-rt-ac68u-router/
But when I try these commands in Putty, nothing works. I got as far turning the swap on --- but I can't figure out the correct set of commands to get the " /jffs/scripts/post-mount " to automatically turn swap on.
Can anyone help me? thank you!!
If you reboot your router, the swap will be inactive until you swapon again. To do this automatically you have to create the file /jffs/scripts/post-mount, or edit it if exists and add the line:
1
2
#!/bin/sh
swapon /tmp/mnt/sda1/myswap.swp
Now every time the router reboots, it will turn on swap.
