Creating virtual wireless interfaces outside of UI
cybergibbons
I'm not keen on only being able to do things through the UI. At the moment I am using my RT-AC66U to take three VLANs in via the WAN port and split them to three distinct 5GHz WiFi SSIDs. No routing is done by the RT-AC66U at all.
The only way I have found to create these wl virtual wireless interfaces is using the guest WiFi network UI.
Is there anyway to do it from the command line?
I'm not sure I well understand what you want to do, but a good place to start would be here: https://github.com/RMerl/asuswrt-merlin/wiki
What I means is that through the UI, you have the ability to create virtual wireless interfaces on the "Guest network" page:
These show as wl0.1 (2.4GHz) and wl1.1 (5GHz) through ifconfig:
wl0.1      Link encap:Ethernet  HWaddr 74:D0:2B:88:AC:D9
           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
           RX packets:66 errors:0 dropped:0 overruns:0 frame:4229
           TX packets:595 errors:2 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:1000
           RX bytes:7928 (7.7 KiB)  TX bytes:124164 (121.2 KiB)
wl1.1      Link encap:Ethernet  HWaddr 74:D0:2B:88:AC:DD
           RX packets:5194 errors:0 dropped:0 overruns:0 frame:1658
           TX packets:6249 errors:1 dropped:0 overruns:0 carrier:0
           RX bytes:934708 (912.8 KiB)  TX bytes:6400529 (6.1 MiB)
How can wl0.1 and wl1.1 be created without the UI?
I can't find any reference to this in the forums or wiki.
You can't do that easily, as there's a lot of nvram settings that have to be set to configure a whole virtual wireless interface. It's not just a matter of running a simple ifconfig command with a few parameters.
