The theory guiding my build: a rack-mount NAS to fit into my 21" deep cabinet, which has at least 8 hot swap drive bays, running FreeNAS. It will be used to back up some documents from my laptop, stream HD movies to a Boxee Box, and down the line, record from a couple of IP security cameras.
From there, I found this case: NORCO RPC-450TH
And then picked these components:
ECS A890GXM-A2(2.0) Motherboard - $120 - Key requirements for me here were dual gig LAN ports and SATA III connections
AMD Athlon II X4 645 Propus 3.1GHz Quad-Core Processor - $80 - Only a few dollars more to go from dual core to quad core, so why not?
(x2) Kingston HyperX Blu 4GB 240-Pin SDRAM DDR3 1600 Desktop Memory - $42 - Seems like a good compromise in terms of speed and capacity
COOLMAX CUL-750B 750W Modular Power Supply - $56 - Key requirements here were the proper connections for the MB, and at least 4 +12v rails to power the hot swap drive bays in the case, so they aren't all powered through a single rail
Transcend JetFlash 700 4GB USB 3.0 Flash Drive Model TS4GJF700 - $11 - To run FreeNAS; want to go USB 3.0, since I understand FreeNAS is compatible with it now, and to be best positioned for future software upgrades
Key questions I have:
(1) Does anyone see any compatability issues with any of these components? I think it should all work together, but I'd like someone to take a second look in case I missed anything!
(2) Is anything here dramatic overkill? I definitely want to err on the side of performance, so a little overkill is ok, but if anything is just ridiculously unnecessary, I'd like to know.
(3) If there is a choke point in this system, where is it?
Thanks for your help in advance!
