Cron job to move files created yesterday
perla
My IP camera can only upload images to the same directory (/mnt/NAS/IPC_FTP/) using FTP. I would like to organize these snapshots by date, so I wrote the following script to automatically move all images from yesterday to a new directory (for example to /mnt/NAS/IPC_FTP/2015-07-14/):
#!/bin/sh
DIR="/mnt/NAS/IPC_FTP/"$(date -d @$(( $(date +"%s") - 86400)) +"%Y-%m-%d")"/"
NAME=".*"$(date -d @$(( $(date +"%s") - 86400)) +"%Y%m%d")".*"
mkdir $DIR
find /mnt/NAS/IPC_FTP/ -type f -regex $NAME -exec mv {} $DIR \;
A date field is a part of the filename, so it was easy the find all images uploaded on yesterday.
A cron job is added to services-start to schedule the script:
#!/bin/sh
cru a ipc_ftp "1 4 * * * /jffs/scripts/ipc_ftp.sh"
sleep 10
/opt/etc/init.d/rc.unslung start
However, it only works if I run the script manually from the console...
I can see in the router's log that the cron job runs the script at the specified time, but it has no effect. What can be the problem? Has the cron job had the necessary permissions to move files?
Thank you very for the help in advance!
An update:
By redirecting the cron job's output:
cru a ipc_ftp "1 4 * * * /jffs/scripts/ipc_ftp.sh > /var/log/cron.log 2>&1"
I get the following error in the log file for the find command:
unrecognized: -type
I have tried to remove that parameter, but now I get:
unrecognized: -regex
It is very strange, because like I said by executing the script from the console manually it runs with no problem...
Do you have entware/optware installed? The base find/busybox does not support the type and regex options. Maybe when you running from the command line you are picking up the other 'ware version?
As john9527 points out, you're picking up the wrong version of find. The cron environment is not the same as the interactive shell environment, so you need to add a PATH statement to your script that includes your optware/entware binaries.
If you're like ppl said above and have optware/entware/etc installed, replace "find" with "/opt/bin/find" in your script. That is one simple fix to your error.
asuswrt has a hard coded default PATH/environment for non-interactive shells. Seems no more polish for a long time.
Thank you everyone for the help!
Yes, I have entware installed, so that "caused" my problem.
However, for my simple task the "dumber" find command is more than enough. I finally used the -name function:
#!/bin/sh
NAME="*"$(date -d @$(( $(date +"%s") - 86400)) +"%Y%m%d")"*"
mkdir $DIR
find /mnt/NAS/IPC_FTP/ -name "$NAME" -exec mv {} $DIR \;
I have learned something, so thanks again!
