crond not running
bpearse
crond crashing
I have been getting my system set up with all the tweaks I like, but have found I have somehow done something that stopped crond from running.
I see in the log that it is started and given PID #320. I do not see anything in the log about it stopping. But when I do a ps it does not show up. And it is not running it's nightly reboot script.
Any ideas? This one has me baffled....
Merlin 3.0.0.4.374.33 final; RT-n16; Entware via script; 3TB Seagate NTFS drive
Here is some more info on this problem. Crond does run at first, as I can see from a ps when I quickly SSH into my router after boot. But within 1-5 minutes after rebooting, crond goes away with no log or error details. Very odd.
Here is my syslog, starting with when crond is initialized. As you can see, there is no evidence of crond stopping, but it does.
....deleted prior log info
Dec 31 16:00:11 crond[319]: crond: crond (busybox 1.20.2) started, log level 8
Dec 31 16:00:12 disk monitor: be idle
Dec 31 16:00:12 kernel: br0: port 1(vlan1) entering disabled state
Dec 31 16:00:12 kernel: vlan1: dev_set_promiscuity(master, 1)
Dec 31 16:00:12 kernel: br0: port 1(vlan1) entering listening state
Dec 31 16:00:12 kernel: br0: port 1(vlan1) entering learning state
Dec 31 16:00:12 kernel: br0: topology change detected, propagating
Dec 31 16:00:12 kernel: br0: port 1(vlan1) entering forwarding state
Dec 31 16:00:13 dnsmasq[269]: read /etc/hosts - 5 addresses
Dec 31 16:00:13 dnsmasq[269]: read /etc/hosts.dnsmasq - 0 addresses
Dec 31 16:00:13 dnsmasq-dhcp[269]: read /etc/ethers - 0 addresses
Dec 31 16:00:13 kernel: Adding 261112k swap on /dev/sda1.  Priority:-1 extents:1 across:261112k
Dec 31 16:00:13 rc_service: hotplug 290:notify_rc restart_nasapps
Dec 31 16:00:13 hotplug[292]: USB /dev/sda3(ntfs) failed to mount at the first try!
Dec 31 16:00:13 kernel: ufsd: use builtin utf8 instead of kernel utf8
Dec 31 16:00:13 dnsmasq[269]: using nameserver 75.75.76.76#53
Dec 31 16:00:13 dnsmasq[269]: using nameserver 75.75.75.75#53
Dec 31 16:00:13 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 31 16:00:13 dnsmasq[269]: exiting on receipt of SIGTERM
Dec 31 16:00:13 dnsmasq[392]: started, version 2.65 cachesize 1500
Dec 31 16:00:13 dnsmasq[392]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Dec 31 16:00:13 dnsmasq[392]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 16:00:13 dnsmasq-dhcp[392]: DHCP, IP range 192.168.1.100 -- 192.168.1.254, lease time 1d
Dec 31 16:00:14 FTP Server: daemon is stoped
Dec 31 16:00:14 dnsmasq[392]: read /etc/hosts - 5 addresses
Dec 31 16:00:14 dnsmasq[392]: read /etc/hosts.dnsmasq - 0 addresses
Dec 31 16:00:14 dnsmasq-dhcp[392]: read /etc/ethers - 0 addresses
Dec 31 16:00:14 dnsmasq[392]: using nameserver 75.75.76.76#53
Dec 31 16:00:14 dnsmasq[392]: using nameserver 75.75.75.75#53
Dec 31 16:00:14 Samba Server: smb daemon is stoped
Dec 31 16:00:14 Samba Server: daemon is started
Dec 31 16:00:15 kernel: nf_conntrack_rtsp v0.6.21 loading
Dec 31 16:00:15 kernel: nf_nat_rtsp v0.6.21 loading
Dec 31 16:00:15 WAN Connection: WAN was restored.
Dec 31 16:00:15 rc_service: udhcpc 371:notify_rc stop_upnp
Dec 31 16:00:16 rc_service: udhcpc 371:notify_rc start_upnp
Dec 31 16:00:16 ddns: clear ddns cache file for server/hostname change
Dec 31 16:00:16 ddns update: ez-ipupdate: starting...
Dec 31 16:00:16 miniupnpd[450]: HTTP listening on port 53729
Dec 31 16:00:16 miniupnpd[450]: Listening for NAT-PMP traffic on port 5351
Dec 31 16:00:16 ddns update: connected to members.dyndns.org (204.13.248.111) on port 80.
Dec 31 16:00:16 ddns update: members.dyndns.org says that your IP address has not changed since the last update
Dec 31 16:00:16 ddns update: asusddns_update: 0
Dec 31 16:00:16 ddns: ddns update ok
Dec 31 16:00:16 rc_service: udhcpc 371:notify_rc stop_ntpc
Dec 31 16:00:16 rc_service: udhcpc 371:notify_rc start_ntpc
Dec 31 16:00:16 dhcp client: bound xxx via xx during 199809 seconds.
Oct  7 09:41:36 rc_service: ntp 453:notify_rc restart_upnp
Oct  7 09:41:36 miniupnpd[462]: HTTP listening on port 52168
Oct  7 09:41:36 rc_service: ntp 453:notify_rc restart_diskmon
Oct  7 09:41:36 disk monitor: be idle
Oct  7 09:41:36 miniupnpd[462]: Listening for NAT-PMP traffic on port 5351
Oct  7 09:41:42 dropbear[465]: Child connection from xxx
Oct  7 09:41:45 kernel: ufsd: sda3 without journal
Oct  7 09:41:45 hotplug[292]: USB ntfs fs at /dev/sda3 mounted on /tmp/mnt/sda3
Oct  7 09:41:45 rc_service: hotplug 292:notify_rc restart_nasapps
Oct  7 09:41:46 FTP Server: daemon is stoped
Oct  7 09:41:47 Samba Server: smb daemon is stoped
Oct  7 09:41:47 Samba Server: daemon is started
Oct  7 09:41:47 FTP server: daemon is started
Oct  7 09:41:47 dropbear[465]: Password auth succeeded for 'xxx' from 1xxx
Well, I have tried re-launching crond from SSH, and it stays up for minutes to hours, but does eventually crash. Nothing gets written to the syslog when it crashes, so I cannot really tell when/why it crashes.
Anyone else having trouble keeping crond running on the latest firmware on RT-N16?
