Hey guys,
I have currently an Asus RT-AC68U, and due to the furniture and cabling, I can only have it on a corner of my apartment (it is approx. 100 sqm).
The router performance is great, I have fibre broadband of 76/20mbps here in London and it always gives me full speed.
However, due to its positioning, the farthest room isn't very well covered, meaning that if the wireless range could go a like 3 meters farther, it would be enough.
Since I`m very happy with Asus performance, I was thinking that maybe upgrading to the RT-AC3200 could give me that little boost in range?
I couldn't find any tests comparing ranges between those routers, only speed, and to be honest, I don't need more speed than what I already have.
I tried buying a cheap wifi extender, but it was 2.4ghz only and the speed was not satisfactory.
Do you think my problem could be solved with that Asus upgrade? Or should I think more in terms of a power line extension?
Thank you very much!
