john9527
Part of the Furniture
A nit problem, but annoying......when opening the System Log - General Log, it opens with the view at the end of the file. But if you try and scroll up or right, it immediately jumps to the top of the file instead of just doing the scroll. Appreciate it if you could put a fix for this on your todo list
