EdwardRutherfordthe5th
Hey guys decided to finally signup as this forum has been a great source of info for my Asus Merlin router.
Here is my current predicament and I need feedback on it
I have Asus RT-AC68U with Merlin 384.4.2
In the LAN/DHCP Server /DNS and WINS Server Setting - I have setup custom DNS to a local DNS of 192.168.20.241
This IP is a Pi-hole which is a network ad blocker. This works great sends all the requests through there and can see everything.
My problem is I have a wifi connected clock and since Pi-hole caches DNS when the clock requests the time from "" It sometimes returns the DNS info that is cache. Causing the time to mess up. It will eventually resync in two hours but it is annoying none the less.
For this clock I can not set an IP on it. I have set a Static IP via the Asus router but will not let me setup individual DNS servers on it.
In Pi-hole there is no option for me to stop caching certain domains and I have asked the devs and they dont even know a manual way of doing it through DNSmasq
What I am currently trying to do is setup DNS Filtering and it is not going so well.
In AiProtection/DNSFilter - I have switched this to "ON"
Global Filter mode - No filtering
C1 192.168.20.241
C2 1.1.1.1
C3 208.67.222.222
I have added the clocks MAC set it to filter Mode "Custom 3" which should be the 208 address above. Clicked + and saved everything.
Things should take effect. However I reboot the clock and it still goes through the pi-hole (192.168.20.241)
I have also tried setting the Global Fitler to "Router" but then internet stops working completely and I have no clue why as shouldn't it be 192.168.20.241 because that is what I setup in LAN DNS? I have also tried Custom 1 which does the same thing. When I have the DNS filter set to those. I check pi-hole and I see a giant spike of DNS requests coming in from 192.168.20.1 (router). I am not sure whats going on there, its almost like it is going around and around in circles but I have no way to confirm that. Also why is the router sending the requests? It should be the clients that are requesting it....
From my understanding if I set global to router it should send to the LAN DNS if specified (currently set to 192.168.20.1) right?
About a year ago I had this working with pihole and everything. I dont know what changed I have reconfirmed all the settings. I would gladly give you any setting (within reason) to help me troubleshoot it.
Here is a thread I mainly used
https://www.snbforums.com/threads/d...c-hosts-on-lan-rt-ac68u-asuswrt-merlin.23694/
Edit: Side note there is no VPN client or Server involved I have turned those off for now to overcomplicate the issues
C1 192.168.20.241
C2 1.1.1.1
C3 208.67.222.222
