Voxel
Part of the Furniture
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-78sf.64890/
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-79sf.65364/
New version of my custom firmware build: 1.0.2.80SF.
Changes (vs 1.0.2.79SF):
1. Toolchain: Go is upgraded 1.14.6->1.15.1.
2. Toolchain: binutils version is upgraded 2.34->2.35.
3. OpenSSL v. 1.0.2 package: change default config directory.
4. net-lan init script bug is fixed (thanks to kamoj).
5. qcawifi.sh: Fix for guest Wi-Fi allowing DNS over TCP (thanks to R. Gerrits).
6. uhttpd: Fix of TLS 1.0/1.1 issue.
7. renice utility is added (needed for kamoj add-on).
8. util-linux package is upgraded 2.35.2->2.36.
9. unbound package (used in stubby) is upgraded 1.10.1->1.11.0.
10. libubox package is upgraded 2020-07-11->2020-08-06.
11. nano package is upgraded 4.9.3->5.2.
12. curl package is upgraded 7.71.1->7.72.0 (fixing CVE-2020-8231).
13. SAMBA: Update SAMBA config generation.
14. sysstat package is upgraded 12.2.2->12.4.0.
15. sqlite package is upgraded 3320100->3330000.
16. ethtool package is upgraded 5.4->5.8.
17. iperf3 package is upgraded 3.8.1->3.9.
18. ez-ipupdate package build (internal developmet issue) is fixed.
19. radvd package build (internal developmet issue) is fixed.
20. phddns package build (internal developmet issue) is fixed.
21. Host tools: upgrade bison to 3.7.1.
22. Host tools: upgrade mpfr to 4.1.0.
23. Host tools: upgrade mpc to 1.2.0.
[Edited]
Quickfix/Snapshot version 1.0.2.80.4SF.
Changes (vs 1.0.2.80SF):
1. Toolchain: Go is upgraded 1.15.1->1.15.2.
2. Toolchain: binutils version is upgraded 2.35->2.35.1.
3. Add ARM acceleration to kernel crypto SHA1.
4. OpenSSL v. 1.1.1 package is upgraded 1.1.1g->1.1.1h.
5. jansson package is upgraded 2.12->2.13.1.
6. libjson-c package is upgraded 0.14->0.15.
7. expat package is upgraded 2.2.9->2.2.10.
8. nano package is upgraded 5.2->5.3.
9. transmission-web-control package is upgraded 2019-07-24->1.6.1+ (2020-09-26).
10. Change SAMBA config generation (for Android/iOS gadgets, issue reported by Rustypouch).
11. Make an order in samba36 Makefile.
12. Fix proftpd issue: change cmdftp (thanks to R. Gerrits).
13. Fix proftpd issue: display size of large file (thanks to R. Gerrits).
[Edited]
New version of my custom firmware build: 1.0.2.80.5SF
Changes (vs 1.0.2.80.4SF):
1. Fix busybox issue: 'date -r' command is fixed.
2. coreutils version of 'date' is available now as '/usr/bin/gnu-date'.
3. dropbear package is upgraded 2020.80->2020.81.
4. uci package is upgraded 2020-04-24->2020-10-06.
5. sysstat is changed to use 'gnu-date now' (sa2: 'gnu-date --date=yesterday').
6. ubus init script is changed to create directory '/var/run/ubus' (/var/run/ubus.sock -> /var/run/ubus/ubus.sock).
7. TZ environment variable is set by /etc/profile.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
[Edited]
[Edited]
The link is:
Voxel.
