Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-41hf-1-0-2-41hf-hw.40481/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-42hf-1-0-2-42hf-hw.40688/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-43hf-1-0-2-43hf-hw.41167/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-44hf-1-0-2-44hf-hw.41301/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-45hf-1-0-2-45hf-hw.41820/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-46hf-1-0-2-46hf-hw.42223/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-47hf-1-0-2-47hf-hw.42721/
hhttps://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-2-54hf-1-0-2-54hf-hw-1-0-3-7hf-1-0-3-7hf-hw.43854/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-3-8hf-1-0-3-8hf-hw.44204/
New version of my custom firmware build: 1.0.3.11HF/1.0.3.11HF-HW.
Changes (vs 1.0.3.9HF):
1. Integration of changes from the stock v. 1.0.3.10.
2. Some NG bugs are corrected.
3. OpenVPN client is optimized.
4. OpenSSL configuration is changed to provide compatibility with ReadyCLOUD 20170711.
5. OpenVPN is upgraded 2.4.4->2.4.5.
6. dropbear package is upgraded 2017.75->2018.76.
7. util-linux package is upgraded 2.30.2->2.31.1.
8. iperf package is upgraded to iperf3 2.0.10->3.4.
9. Beta support of R8900.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Important: reset to factory settings is needed after flasing.
Difference 1.0.3.11HF-HW vs 1.0.3.11HF: “HW” version means hardware acceleration of OpenSSL.
P.S. It is recommended to disable Router Auto Firmware Update. Otherwise your router might be upgraded suddenly by stock version.
Voxel.
PSV-2017-3170 http://kb.netgear.com/en_US/000055194/
PSV-2017-3167 http://kb.netgear.com/en_US/000055193/
PSV-2017-3093 http://kb.netgear.com/en_US/000055191/
NOTE: reset is needed!PSV-2017-3167 http://kb.netgear.com/en_US/000055193/
The link is:
Voxel.
