Custom IPTables Rules for DNS Redirect
AdrianH
I want to add some rules into iptables so that my Google/Nest smart devices stop calling Google DNS directly, and the Google DNS calls they do are redirected to my AdGuard Home DNS server which will reply with the appropriate DNS records. I know I can probably use DNSFiltering, but want to experiment with IPTable rules.
I originally just blocked the DNS calls as follows:
iptables -I FORWARD -d 8.8.8.8 -j REJECT
iptables -I FORWARD -d 8.8.4.4 -j REJECT
These are my rules to redirect Google DNS to my AGH server (192.168.10.14). I put them together after reading various posts about doing this, they look correct to me?
iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to 192.168.10.14
iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to 192.168.10.14
iptables -t nat -A PREROUTING -p udp -d 8.8.4.4 --dport 53 -j DNAT --to 192.168.10.14
iptables -t nat -A PREROUTING -p tcp -d 8.8.4.4 --dport 53 -j DNAT --to 192.168.10.14
iptables -t nat -A POSTROUTING -j MASQUERADE
Also wanting to know which script should I add these rules into.
According to User scripts · RMerl/asuswrt-merlin.ng Wiki · GitHub I could likely use
firewall-start
nat-start
and I am thinking
firewall-start
nat-start
is the correct one.
Any comments or advice will be appreciated
The following ...
iptables -t nat -A PREROUTING -p tcp -d 8.8.8.4 --dport 53 -j DNAT --to 192.168.10.14
... should be ...
The following ...
... should be ...
ah, thanks for picking up my typo. Updated the post.
The above rules for redirection is working, the DNS queries are being sent to my AdGuard Home server.
BUT....the issue is that the source of the DNS queries is now the router, and not the device actually doing the DNS query.
As well as with and without this
Is there a way to specify in the rule to keep the source IP when redirecting the query to the AGH server?
