Custom Script event for new LAN/WLAN clients (dhcp)?
Stefan1200
I saw in the documentation that a user script for an dhcpc-event is possible. But the documentation talks about DHCP events on the WAN interface. Is there something related for LAN/WLAN clients, or did I misunderstand the documentation?
I want to create something like a user script, which sends me a mail that a new DHCP client was connected to my LAN, maybe with information like IP address and more, if possible.
I suppose logging as a DHCP client (WAN) is plausible, but it makes more sense in the context of a DHCP server (LAN), which is what dhcp-script does.
In my case, a "dhcp-script=" definition had not already been defined in /etc/dnsmasq.conf
# cat /jffs/scripts/dnsmasq.postconf
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_append "dhcp-host=00:24:e4:5f:00:00,192.168.66.110,Therm" $CONFIG
pc_append "dhcp-host=00:24:e4:5c:00:00,192.168.66.111,Scale" $CONFIG
pc_delete "dhcp-option=dnsf5" $CONFIG
pc_delete "dhcp-option=dnsf6" $CONFIG
pc_append "dhcp-script=/jffs/scripts/log-dhcp.sh" $CONFIG
pc_append "neg-ttl=3600" $CONFIG
pc_delete "no-negcache" $CONFIG
pc_delete "servers-file=/tmp/resolv.dnsmasq" $CONFIG
. /opt/share/diversion/file/post-conf.div # Added by Diversion
I only wanted DHCP events to be logged by the syslog daemon.
# cat /jffs/scripts/log-dhcp.sh
#!/bin/sh
myscriptname=$(/usr/bin/basename $0)
/usr/bin/logger -t ${myscriptname} -p local6.info "Action $1, MAC $2, IP_address $3, Hostname $4"
If your router already has a "dhcp-script=" definition in /etc/dnsmasq.conf, then
  • Use pc_replace instead of pc_append
  • At the end of your script call whatever the existing dhcp-script had been calling
Thanks for all your hints, I will check this out soon. :)
