Laxarus
Hello can anyone help me figure out why this script is giving me a syntax error? The same script runs perfectly on my Synology NAS.
I tried dos2unix mtk.sh but the result is the same.
mtk.sh: line 3: syntax error: unexpected "("
Bash:
#!/bin/env bash
_LIST_TOOLS_=( "curl" "awk" "sed" )
# List of Colors
Light_Red="\033[1;31m"
Light_Green="\033[1;32m"
Yellow="\033[1;33m"
Light_Blue="\033[1;34m"
Light_Purple="\033[1;35m"
Light_Cyan="\033[1;36m"
NoColor="\033[0m"
function printf_() {
if [[ $2 == 'title' ]]; then
printf "\n\n\t\t ${Light_Purple}%s${NoColor} \n" "$1"
elif [[ $2 == 'header' ]]; then
printf "\n\n${Light_Cyan} [+] %-20s ${NoColor} \n" "$1"
else
printf " |--[+] %-20s : %b\n" "$1" "$2"
fi
function check_program() {
for arr_tools in ${_LIST_TOOLS_[@]}; do
if ! [ -x "$(command -v $arr_tools)" ]; then
printf_ "ERROR | $arr_tools Is Not Installed" header
exit 1
fi
done
function MD5Salt() {
req=$(curl -s $_URL_/login | grep -iE 'md5.*password')
if [[ $(echo $req | wc -m) -le 10 ]]; then
printf_ "Status" "${Light_Green}Already Logged In${NoColor}"
printf_ "Disconnect With" "${Yellow}curl -qI -X GET $_URL_/logout${NoColor}"
exit 0
fi
salt1=$(echo "$req" | awk -F "'" '{print $2;}')
salt2=$(echo "$req" | awk -F "'" '{print $4;}')
printf " |--[+] %-20s : " "Encoded Salt"; echo "$salt1$salt2"
printf_ "Decoded Salt" "$salt1$salt2"
# prevent error null byte on input
_salted_pass_=$(printf "$salt1$_PASS_$salt2" | tr -d '\0')
function skidipapap() {
printf_ "Userame" $_USER_
printf_ "Password" $_PASS_
printf_ "Hashed Password" $hashed_passwd
req=$(curl -s -X POST $_URL_/login -d username=$_USER_ -d password=$hashed_passwd -d dst= -d popup=true)
if [[ $? -eq 0 && $(echo $req | grep -w 'You are logged in' | wc -l) -eq 1 ]]; then
printf_ "Status" "${Light_Green}SUCCESS${NoColor}"
else
printf_ "Status" "${Light_Red}FAILED${NoColor}"
fi
function main() {
check_program
printf_ "Params" header
if [[ $_AUTO_DISCOVER_ -eq 1 ]]; then
printf_ "URL" "$_URL_ [ Auto Discovery ]"
else
printf_ "URL" $_URL_
fi
printf_ "Username" $_USER_
printf_ "Decoding Salt" header
MD5Salt
printf_ "Hashing Password" header
printf_ "Plain Password" "$_PASS_"
hashed_passwd=$(echo -ne $_salted_pass_ | md5sum | awk '{print $1}')
printf_ "Hashed Password" "$hashed_passwd"
printf_ "Connecting" header
skidipapap
clear; printf_ "Automated Login Captive Portal | berrabe" title
if [[ $1 == "" || $2 == "" ]]; then
printf_ "HELP PAGE" header
printf_ "Params" "${Yellow}mtk.sh < URL > < USER > < PASS >${NoColor}"
printf_ "Example 1" "${Light_Blue}mtk.sh http://10.0.0.1 berrabe 12345${NoColor}"
printf_ "Example 2" "${Light_Blue}mtk.sh http://10.0.0.1 admin${NoColor}"
printf_ "Auto Discovery URI" "${Light_Blue}mtk.sh auto admin${NoColor}"
exit 1
else
if [[ $1 == "auto" ]]; then
_URL_="http://$(ip route show | grep -wE '^default via' | awk '{print $3}')"
_AUTO_DISCOVER_=1
else
_URL_=$1
fi
_USER_=$2
_PASS_=$3
main
fi
