Custom SSL cert with Merlin FW....
mlai
Hello,
Is there any way to use certs from SSL vendors with Merlin FW? I am on 378.56/378.55 and I had followed online tutorials for previous firmware versions of uploading cert.pem and key.pem to /etc via SSH.
The problem is that when httpd is restarted, it ignores the existing cert.pem and key.pem and regenerates a self-issued cert........
OK. I did 3 extra steps:
1) remove the existing cert.pem, key.pem, server.pem from /etc before restart_httpd
2) chmod to read only after uploading custom cert.pem and key.pem
3) clear any existing crt in nvram by "nvram set https_crt_file="
Now everything is a-ok!
I did the chmod (i used WinSCP to copy the files and change the perms as i hate all that mucking about on the command line).
I also note that a reboot wasn't needed and that the browser detected the new cert on the final restart_httpd
I also copied my keychain.pem over too.
I didn't remove the server.pem and it seems to work without needing to remove that
Thanks for the links and hints - worked well.
--edit-- after changing the admin pwd the old self signed cert returned and the cert.pem and key.pem reverted to the old one. I think solution may be to deleted the server.pem.
