TheScotsman
I've been playing with the "Traffic Analyzer - Statistic" function on my Asuswrt-Merlin install (388.2 beta1 on a GT-AXE11000), and have a couple questions about customizing it:
1) What's the source of info it uses to classify the traffic, and can that be customized at all? For instance, there are a number of sites it tracks in details (such as Adobe.com) that really don't care about, happy to lump those in with general SSL/TLS traffic to declutter the reports. But I'd also like to be able to call out specific traffic (for instance, Backblaze traffic that is going into the SSL/TLS bucket now I'd like to call out separately as backup activity, or even just as Backblaze.com so it's easy to identify). Can that classification list be adjusted at all?
2) Is there anyway to redirect where it writes the database to? Currently it writes to /jffs/.sys/TrafficAnalyzer ... I was under the impression that writing too much to /jffs could be a bad thing, I'd like to redirect that over to a USB-attached drive; sure, that might also corrupt, but at least it won't render the router useless if it does.
Thanks!
Thanks!
