CVSS High 8.1 - CVE-2015-8960 with firmware 3004.388.8_2
datorexpert67
Vulnerability​
NameCVE-2015-8960
Severity
8.1 (High)
QoD75 %
Host192.168.50.1
Location
Detection Result​
The host carries the product: cpe:/a:ietf:transport_layer_security:1.2
It is vulnerable according to: CVE-2015-8960.
The product was found at: 8443/tcp.
The TLS protocol 1.2 and earlier supports the rsa_fixed_dh, dss_fixed_dh, rsa_fixed_ecdh, and ecdsa_fixed_ecdh values for ClientCertificateType but does not directly document the ability to compute the master secret in certain situations with a client secret key and server public key but not a server secret key, which makes it easier for man-in-the-middle attackers to spoof TLS servers by leveraging knowledge of the secret key for an arbitrary installed client X.509 certificate, aka the "Key Compromise Impersonation (KCI)" issue.
Product Detection Result​
So you really signed up just to post info on a vulnerability that was fixed shortly after it was found - in 2015?
@datorexpert67, FYI there is a specific subforum for Asus-Merlin firmware discussion:
If you have a specific question, like for example; is CVE-2015-8960 patched, its wise to ping the firmware developer @RMerlin to see if they can respond. It also helps to check the Asus-Merlin release notes to see if the CVE has already been patched.
Do you have any PoC showing how this is actually exploitable? I see the report comes from a scanning tool - these are notorious for generating false positives, as they don`t explicitly test for a vulnerability to be present, but just check for generic parameter such a software version, and assume vulnerability whenever these parameters are found. In the case of this specific CVE, quite a few tools will generate a false positive whenever a service allows TLS 1.2 connections.
Thanks, but nothing in the release notes. I will ping RMerlin.
