Hello Everyone,
I'm trying to setup a VPN with Cyberghost through OpenVPN,
however when I create the profile on Cyberghost I have these both options :
OpenVPN or OpenVPN <=2.3
the second option has way less servers and doesn't have servers for the country I'm trying to connect to, but it's the only option working for me,
when I select the first option to create a profile I have this error on the log :
do you have any idea what's the difference between both and if it's possible for me to get connected on the normal OpenVPN instead of the <=2.3 ?
Thank you
Apr 22 12:36:02 rc_service: httpd 24002:notify_rc restart_vpnclient2;restart_dnsmasq
Apr 22 12:36:02 custom_script: Running /jffs/scripts/service-event (args: restart vpnclient2)
Apr 22 12:36:02 openvpn-routing: Clearing routing table for VPN client 2
Apr 22 12:36:02 ovpn-client2[28837]: Options error: Unrecognized option or missing or extra parameter(s) in config.ovpn:32: ncp-disable (2.6.0)
Apr 22 12:36:02 ovpn-client2[28837]: Use --help for more information.
Apr 22 12:36:02 openvpn: Starting OpenVPN client 2 failed!
Thank you
