D-Link Announces 2.5 Gbps SMB/SME Managed Switches
Julio Urquidi
News Editor
The 8-port D-Link DMS-1100 Series is a line of multi-gigabit managed switches supporting 2.5 Gbps, 1000 Mbps and 100 Mbps network speeds, with two 10 GbE SFP+ uplink ports.
Each of the eight 2.5 GbE ports can auto-detect the speed of a connected device and adjust itself to the right link rate. Dubbed by D-Link as “cost-effective”, these new switches are compliant to the IEEE 2.5 BASE-T standard and use Cat 5E Ethernet cable, letting customers upgrade to 2.5 Gbps networking speeds without needing to re-cable their network infrastructure.
A second model in the line, the DMS-1100 -10TP, is an 8-port PoE managed switch with an overall power budget of 240W (30W x 8 ports).
Additional features include Layer 2 functions (STP, RSTP, ERPS, 802.1Q/Port/Asymmetric VLAN, Port mirroring, IGMP/MLD Snooping, LACP), D-Link’s Network Assistant Utility, web-based GUI management, SNMP MIB for remote NMS, D-Link Safeguard Engine (security) and DoS attack prevention. “Green” power saving features include LED shut-off, link status, port shutoff, and hibernation.
Though pricing for the D-Link DMS-1100 Series wasn’t given at this time, D-Link did say the two new switches will be available through VARs, channel partners, and retailers early this month.
Over $500 for the non PoE version.
For that kind of money you can get Buffalo's 10Gbps equivalent, although it admittedly doesn't have the two SFP+ ports.
Still, nice to see more products that offer speeds above 1Gbps.
Sub $200 managed switch with Distributed Switch Architecture (stackable switch fabric with each switch port configurable using iproute2 or similar command set) is available today.
Details https://github.com/systemd/systemd/issues/7478
If it isn't enough, you just add another one. DSA lets you extend a network bridge across devices as if it was one device. You can choose a device with an SPF or not depending on your needs.
Netdev 2.1 - Distributed Switch Architecture By Andrew Lunn, Vivien Didelot, Florian Fainelli, 2017, 25 minutes
Distributed Switch Architecture, A.K.A. DSA April 2017, 7 pages.
https://www.netdevconf.org/2.1/papers/distributed-switch-architecture.pdf
for $400 you can get a fully managed mikrotik switch with 16 SFP+ ports, 2 PSUs that will take 2.5G/5G ethernet SFP+ modules. even though factoring the price pf modules, you get 2x more ports at 160gb/s forwarding capacity vs dlink's 40gb/s. this also allows you to use used SFP+ cards and use SFP+ direct for less.
