Daylight saving time CANNOT be manually adjusted.
qneeuqeo
My config is RT-AC68U and 3.0.0.4.376.47_0 (Merlin build)
I found a tutorial on another post with the screenshot like this:
attachment.php
However With the build I'm on , I couldn't see the option to adjust option of DST, please see attachment for my screenshot.:confused:
Can anybody please tell me how to adjust the DST manually.
Regards,
Sean
attachment.php
Regards,
Sean
Asuswrt is using quite old DST rules. The manual adjustment is only visible for timezone for which these old rules were using DST. If you try a different timezone the manual DST setting will then appear.
