DD-WRT Asus RT-AC87U only seeing VHT (40+40 MHz) for 5GHz
ngerasimatos
I am only seeing VHT (40+40 MHz) for 5GHz as an option and from what I read I should be able to see the value of VHT (80+80 MHz)
Router Name DD-WRT
Router Model Asus RT-AC87U
Firmware Version DD-WRT v3.0-r27745 std (08/25/15)
Kernel VersionLinux 3.10.87 #4535 SMP Tue Aug 25 05:33:22 CEST 2015 armv7l
MAC AddressAC:9E:17:95:61:FA
Hostname
WAN Domain Name
LAN Domain Name
Current TimeSun, 06 Sep 2015 22:27:10
Uptime 2 days, 6:09
NVRAM30.08 KB / 64 KB
CIFS(Not mounted)
JFFS2(Not mounted)
Is this an issue with the firmware? Using the regular Asus firmware I see 80Mhz as an option.
Router Name DD-WRT
Hostname
WAN Domain Name
LAN Domain Name
Uptime 2 days, 6:09
CIFS(Not mounted)
JFFS2(Not mounted)
All of the routers currently out, do not support 160 Mhz yet. 80 Mhz = 40+40, just FYI. Not a bug. Just a relabeling.
